Mjh2157
Dec 23, 2021Tutor
M4300-16X (XSM4316PA) and ORBI RBK854 CONFIGURATION
Hi, The auto fill menu for the model numbers on this post doesn't have my models, so below is my equipment: Modem - Nighthawk CM2000 Multi-gig Router with 3 Satelites over ethernet backhaul ...
- Dec 23, 2021
Can't find any complete specs of this 828LM LiftMaster Internet Gateway. They only talk of "Ethernet". In case this is a simple 10 Mb/s Ethernet port (plenty of performance for a door opener), the M4300-16X (XSM4316PA) does support Fast Ethernet (100 Mb/s) and up, classic 10 Mb/s Ethernet won't bring up a link. This is fine on the Orbi however if I have it right. I'd suggest to try a simple small non-managed switch in between the M4300 and the LiftMaster for a test or work-around.
schumaku
Dec 23, 2021Guru - Experienced User
Mjh2157
Dec 23, 2021Tutor
Thank you very much, will do. Have a Happy and Healthy New Year
Best Regards,
Matt
