Carva
Dec 13, 2017Aspirant
M4300-24X Routing guide
Hi Sir, I would like to deploy OSPF & RIP protocol using M4300-24X. May I know if do you have an example scenario of document to refer to? Thanks. C.
Retired_Member
Dec 14, 2017Hi Carva,
Welcome to the community!
For dynamic routing protocol(RIP&OSPF) admin guide, please refer to M4300 Software Administratrion Manual. Click the Link and go to Chapter 6(RIP) and Chapter 7(OSPF) for typical scenario configuration.
Hope it helps!
EricZ
NETGEAR employee
- Retired_MemberDec 17, 2017
Hi Carva,
I just want to follow-up on this. Does this suggestion resolve your problem?
With regard to resolve your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- CarvaDec 19, 2017Aspirant
Hi Eric,
Thanks for the quick response and support.
May I know if do you have some example scenario that I could refer to?
The guide that you provide is good, but I still don't know how to implement it in a real network environment.
Thanks.
C.
- Retired_MemberDec 19, 2017
Actually, the link above is typical network topo and confuguraiton for RIP and OSPF.
If you want to deploy RIP or OSPF in your real network and need some further more support, I suggest you provide your network topo and design requirement. According the detailed requirement, We can give you detailed suggestion.
