jmozdzen
Nov 27, 2019Tutor
m4300-24x: strange ARP forwarding effect
Hi all, seems I cannot get to the bottom of this by myself, although I stripped my config to (what I feel is) minimum: - M4300-24x 10G switch - on one port, I have a (newly attached) server,...
kevin_hong
Jan 15, 2020Apprentice
Hi jmozdzen ,
Welcome to community,
Could you please provide me with "tech support" ? it will be very helpful to check to find the casue of the issue you are facing.
Thank you
jmozdzen
Jan 15, 2020Tutor
Hi Kevin,
thank you for your offer to look into this. Since I've just had a round of extra reboots, I'll rather wait for the next occurance of this issue, so that the tech supp will contain a "proven" case of trouble - no use in someone wasting time of going through the logs to only find out nothing bad had happend since last reboot.
I'll update this thread once I can report back.
Thanks & best regards,
J
