SGNOC
Nov 21, 2023Aspirant
M4300-24X24F Basic Layer 2 Switching Only Configuration Issue
I'm trying to replace an older switch with this new M4300-24X24F switch, but am having trouble getting it configured the way that I need. Just to get things operational, I am trying to configure ...
SGNOC
I've done some additional testing and changed all non trunk ports to switchport mode access, along with switchport access vlan 5. I've also removed all ip routing options that I could find. That has disabled the management access to the 10.10.5.8 on VLAN 5, so it seems that some routing has to be enabled for that to work. I'll tackle that once I get the rest working. Still trying to get just switching w/ vlans working along with the trunk ports from the router/firewall and to another downstream switch. Attached is my updated config file.
- SGNOCNov 22, 2023Aspirant
I was able to get the switch working as a layer 2 switch from the last config posted by removing the native vlan trunk lines from the trunks. The router and switches on either side of this switch were expecting untagged vlans on everything and I mistakenly thought the trunk line with native vlan trunk configured would just tag incoming traffic that was not tagged with the native tag, but it also removed the vlan tag for the native vlan on the way out, which the devices were not accepting apparently.
My only remaining question is if anything else looks out of place in the config, and if I can enable the management interface on a specific vlan, which enables some routing features and the default gateway, without having the switch turn into routing mode and start routing traffic that should have gone to the router?
