maindriver's avatar
maindriver
Apprentice
Oct 18, 2024
M4300-24X24F high cpu usage on 12.0.19.4
Any ideas?
  • BrianL's avatar
    BrianL
    NETGEAR Moderator
    Hi maindriver,
    Is it more than 80-90% when the network is busy? Can you share the tech-support file via PM so I can take a look?
    Kind regards,
    BrianL
  • BrianL's avatar
    BrianL
    NETGEAR Moderator
    Hi maindriver,
    I have read your PM. Does the high CPU utilization of 80% affect the switch functionality? Does the previous firmware notas the previous Firmware doesn't exhibit this behavior?
    Kind regards,
    BrianL
ProSupport for Business
