maindriver
Sep 09, 2024Apprentice
M4300-24x24f some network devices unpingable (reboot of switch fixes it)
We've had this as our core switch for a number of years. Typically it's been pretty solid (600 day uptime previously) As of late, we're experiencing an issue where our monitoring solutions are r...
ErwinL
Sep 10, 2024NETGEAR Moderator
Hello maindriver
And welcome to the NETGEAR Community! 🙂
A technical support file would be helpful in reviewing what has transpired. Since you have just enabled the syslogs, you can also check those later. In the meantime, could you please share the output of the tech support file information under 'show logging buffered'
Have a lovely day,
Erwin
Netgear Team
- maindriverSep 21, 2024Apprentice
*************** show logging buffered ***************
Buffered (In-Memory) Logging : enabled
Buffered Logging Wrapping Behavior : On
Buffered Log Count : 108554
Buffered Log Threshold (lines) : 160<14> Sep 21 08:46:49 ncore1-1 SIM[Sim Req]: sysapi_hpc.c(3507) 863626 %% Processing RPC, Transport StatsGet Req
<14> Sep 21 08:46:46 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863618 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:46:23 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863581 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:46:22 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863580 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed
<14> Sep 21 08:46:15 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863569 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed
<14> Sep 21 08:46:10 ncore1-1 ARP[ipMapForwarding]: arp.c(2078) 863562 %% Purged old entries. Reduced ARP cache from 759 to 750 entries in 24 msec.
<14> Sep 21 08:46:03 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863550 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:45:53 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863538 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed
<14> Sep 21 08:45:43 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863527 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:45:40 ncore1-1 General[emWeb]: main_login.c(915) 863518 %% HTTP Session 12 initiated for user admin connected from 192.168.1.187
<14> Sep 21 08:45:40 ncore1-1 CLI_WEB[emWeb]: emweb_common_custom.c(162) 863517 %% HTTP Session 12 started for user admin connected from 192.168.1.187
<14> Sep 21 08:45:35 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863513 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed
<14> Sep 21 08:45:33 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863509 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed
<14> Sep 21 08:45:27 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863502 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:45:21 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863498 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed
<14> Sep 21 08:45:04 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863473 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:45:00 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863472 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed
<14> Sep 21 08:44:59 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863471 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:44:53 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863468 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:44:44 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863460 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:44:36 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863459 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed
<14> Sep 21 08:44:17 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863426 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:43:53 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863384 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:43:29 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863286 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:43:17 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863264 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:43:09 ncore1-1 ARP[ipMapForwarding]: arp.c(2078) 863261 %% Purged old entries. Reduced ARP cache from 759 to 740 entries in 15 msec.
<14> Sep 21 08:43:02 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863252 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:42:42 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863234 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:42:37 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863221 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed
<14> Sep 21 08:42:18 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863195 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:42:18 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863194 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed
<14> Sep 21 08:41:55 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863178 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:41:55 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863177 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed
<14> Sep 21 08:41:39 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863152 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:41:15 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863147 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:41:12 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863144 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:41:09 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863143 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed
<14> Sep 21 08:40:58 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863140 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:40:52 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863139 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:40:36 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863131 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:40:32 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863129 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed
<14> Sep 21 08:40:20 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863126 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:40:08 ncore1-1 ARP[ipMapForwarding]: arp.c(2078) 863123 %% Purged old entries. Reduced ARP cache from 759 to 751 entries in 12 msec.
<14> Sep 21 08:39:57 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863120 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:39:40 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863115 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed
<14> Sep 21 08:39:33 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863114 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:39:09 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863107 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<13> Sep 21 08:38:51 ncore1-1 SNOOP[snoopTask]: snooping_timer.c(602) 863099 %% Timer for Group Membership Interval has expired! Removing membership for VLAN 24 Mac 01:00:5E:05:03:07 intIfNum 1/0/20
<14> Sep 21 08:38:46 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863095 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:38:42 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863085 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed
<14> Sep 21 08:38:26 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863075 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:38:12 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863057 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed
<14> Sep 21 08:38:10 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863054 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed
<14> Sep 21 08:37:59 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863036 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<13> Sep 21 08:37:48 ncore1-1 TRAPMGR[trapTask]: traputil.c(753) 863010 %% Session 0 of type 3 ended for user admin connected from 192.168.1.187.
<14> Sep 21 08:37:48 ncore1-1 CLI_WEB[UtilTask]: login_sessions.c(178) 863009 %% SSH Session 0 ended for user admin connected from 192.168.1.187
<14> Sep 21 08:37:47 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 863006 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed
<14> Sep 21 08:37:39 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862993 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:37:15 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862954 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:37:07 ncore1-1 ARP[ipMapForwarding]: arp.c(2078) 862951 %% Purged old entries. Reduced ARP cache from 759 to 749 entries in 12 msec.
<14> Sep 21 08:36:55 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862948 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:36:36 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862935 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:36:32 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862928 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed
<14> Sep 21 08:36:12 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862913 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:35:49 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862879 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:35:33 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862856 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:35:33 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862855 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed
<14> Sep 21 08:35:32 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862849 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed
<14> Sep 21 08:35:13 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862827 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:35:13 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862826 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed
<14> Sep 21 08:34:50 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862813 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:34:34 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862804 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed
<14> Sep 21 08:34:26 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862797 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:34:06 ncore1-1 ARP[tRpcsrv.02000]: arp.c(2078) 862713 %% Purged old entries. Reduced ARP cache from 759 to 755 entries in 14 msec.
<14> Sep 21 08:33:58 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862690 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:33:54 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862677 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed
<14> Sep 21 08:33:35 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862608 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:33:11 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862544 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:33:03 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862542 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed
<14> Sep 21 08:32:43 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862534 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
<14> Sep 21 08:32:36 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862519 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed
<14> Sep 21 08:32:22 ncore1-1 UNITMGR[emWeb]: unitmgr.c(7077) 862485 %% Configuration propagation successful for config type 0
<14> Sep 21 08:32:20 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862481 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed- maindriverSep 21, 2024Apprentice
<13> Sep 21 08:32:02 ncore1-1 TRAPMGR[trapTask]: traputil.c(753) 862447 %% Session 0 of type 3 started for user admin connected from 192.168.1.187. <14> Sep 21 08:31:56 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862436 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:31:37 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862330 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:31:35 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862324 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed <14> Sep 21 08:31:17 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862270 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:31:05 ncore1-1 ARP[ipMapForwarding]: arp.c(2078) 862246 %% Purged old entries. Reduced ARP cache from 759 to 744 entries in 12 msec. <14> Sep 21 08:30:53 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862242 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:30:51 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862238 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed <11> Sep 21 08:30:46 ncore1-1 SNOOP[dtlTask]: snooping.c(109) 862213 %% Received an invalid packet with Src IP: 0.0.0.0 and Dst IP: 255.255.255.255 on port 1/0/18 with ipheader length:328 packet buffer length:290 <14> Sep 21 08:30:34 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862191 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:30:34 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862190 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:30:22 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862177 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:30:22 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862176 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:30:07 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862172 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed <14> Sep 21 08:29:58 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862166 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:29:50 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862162 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:29:34 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862157 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:29:11 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862137 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:28:47 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862120 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:28:39 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862113 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed <14> Sep 21 08:28:31 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862108 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:28:24 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862103 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:28:04 ncore1-1 ARP[ipMapForwarding]: arp.c(2078) 862097 %% Purged old entries. Reduced ARP cache from 759 to 744 entries in 16 msec. <14> Sep 21 08:27:56 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862076 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <13> Sep 21 08:27:34 ncore1-1 SNOOP[snoopTask]: snooping_timer.c(602) 862071 %% Timer for Group Membership Interval has expired! Removing membership for VLAN 24 Mac 01:00:5E:05:01:09 intIfNum 1/0/20 <14> Sep 21 08:27:32 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862069 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:27:10 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862056 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed <14> Sep 21 08:27:09 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862050 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:26:45 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862023 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:26:26 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862010 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed <14> Sep 21 08:26:22 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 862003 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:25:58 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861966 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:25:38 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861935 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:25:23 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861917 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:25:03 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861902 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:25:03 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861901 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:25:03 ncore1-1 ARP[ipMapForwarding]: arp.c(2078) 861900 %% Purged old entries. Reduced ARP cache from 757 to 745 entries in 10 msec. <14> Sep 21 08:24:39 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861890 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:24:39 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861889 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:24:12 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861852 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:24:12 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861851 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:23:44 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861816 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:23:44 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861815 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:23:28 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861801 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:23:18 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861793 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:23:18 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861792 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <11> Sep 21 08:23:08 ncore1-1 SNOOP[dtlTask]: snooping.c(109) 861783 %% Received an invalid packet with Src IP: 0.0.0.0 and Dst IP: 255.255.255.255 on port 1/0/20 with ipheader length:328 packet buffer length:290 <14> Sep 21 08:22:53 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861775 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:22:53 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861774 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:22:29 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861757 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:22:29 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861756 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:22:25 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861755 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:22:06 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861747 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:22:06 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861746 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:22:02 ncore1-1 ARP[ipMapForwarding]: arp.c(2078) 861744 %% Purged old entries. Reduced ARP cache from 757 to 736 entries in 19 msec. <14> Sep 21 08:22:02 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861743 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed <14> Sep 21 08:21:42 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861738 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:21:42 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861737 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:21:25 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861730 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:21:09 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861716 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:21:02 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861698 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:21:02 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861697 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:21:00 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861688 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed <14> Sep 21 08:20:40 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861667 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:20:40 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861666 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:20:33 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861659 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed <14> Sep 21 08:20:27 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861652 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:20:27 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861651 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <13> Sep 21 08:20:25 ncore1-1 SNOOP[snoopTask]: snooping_timer.c(602) 861647 %% Timer for Max Response Time has expired! Removing membership for VLAN 24 Mac 01:00:5E:05:00:05 intIfNum 1/0/20 <11> Sep 21 08:20:13 ncore1-1 SNOOP[dtlTask]: snooping.c(109) 861631 %% Received an invalid packet with Src IP: 0.0.0.0 and Dst IP: 255.255.255.255 on port 1/0/17 with ipheader length:328 packet buffer length:290 <11> Sep 21 08:20:10 ncore1-1 SNOOP[dtlTask]: snooping.c(109) 861628 %% Received an invalid packet with Src IP: 0.0.0.0 and Dst IP: 255.255.255.255 on port 1/0/17 with ipheader length:328 packet buffer length:290 <11> Sep 21 08:20:09 ncore1-1 SNOOP[dtlTask]: snooping.c(109) 861622 %% Received an invalid packet with Src IP: 0.0.0.0 and Dst IP: 255.255.255.255 on port 1/0/17 with ipheader length:328 packet buffer length:236 <14> Sep 21 08:20:04 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861609 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <13> Sep 21 08:19:49 ncore1-1 SNOOP[snoopTask]: snooping_timer.c(602) 861561 %% Timer for Max Response Time has expired! Removing membership for VLAN 24 Mac 01:00:5E:05:00:13 intIfNum 1/0/20 <14> Sep 21 08:19:38 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861517 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:19:16 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861467 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:19:05 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861464 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed <14> Sep 21 08:19:01 ncore1-1 ARP[ipMapForwarding]: arp.c(2078) 861463 %% Purged old entries. Reduced ARP cache from 759 to 756 entries in 8 msec. <14> Sep 21 08:18:45 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861456 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:18:33 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861440 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:18:25 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861437 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:17:58 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861411 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:17:34 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861366 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:17:10 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861352 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:16:47 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861343 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:16:27 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861335 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:16:07 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861325 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:16:00 ncore1-1 ARP[ipMapForwarding]: arp.c(2078) 861320 %% Purged old entries. Reduced ARP cache from 759 to 758 entries in 7 msec. <14> Sep 21 08:15:40 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861302 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:15:32 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861299 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:15:25 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861294 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:15:25 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861292 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed <14> Sep 21 08:15:12 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861286 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:15:08 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861285 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:14:41 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861279 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:14:29 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861272 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:14:21 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861258 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:13:57 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861224 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed <14> Sep 21 08:13:53 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861219 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:13:38 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861201 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:13:30 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861190 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:13:06 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861172 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:12:59 ncore1-1 ARP[ipMapForwarding]: arp.c(2078) 861169 %% Purged old entries. Reduced ARP cache from 754 to 725 entries in 16 msec. <14> Sep 21 08:12:35 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861155 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:12:31 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861151 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:12:28 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861150 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed <14> Sep 21 08:12:11 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861142 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:12:07 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861141 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:11:43 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861133 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:11:24 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861128 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:11:00 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861121 %% VOIP mode on interface 1/0/43 is disabled.Control frames will not be processed <14> Sep 21 08:11:00 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861120 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:10:37 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861114 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:10:33 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861111 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:10:25 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861110 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed <14> Sep 21 08:10:10 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861105 %% VOIP mode on interface 1/0/11 is disabled.Control frames will not be processed <14> Sep 21 08:10:05 ncore1-1 VOIP[dtlTask]: voip_control.c(183) 861104 %% VOIP mode on interface 1/0/22 is disabled.Control frames will not be processed
