OperatorITSP
Apr 13, 2026Guide
M4300 24x24F Stack member failure
Hello We are having situation where 02 member of two member stack is crashing for unknown reason. We had this crash multiple times on various firmware. We do not run multicast and traffic is re...
OperatorITSP
Apr 13, 2026Guide
Logs below
<13> Jan 2 23:45:26 CORE01-2 TRAPMGR[dot1s_task]: traputil.c(795) 962 %% Spanning Tree Topology Change Received: MSTID: 0 lag 5 """
<13> Jan 2 23:45:25 CORE01-2 TRAPMGR[SNMPCfgTask]: traputil.c(795) 961 %% Cold Start: Unit: 0"""
<12> Jan 2 23:45:11 CORE01-2 DRIVER[bcmDISC]: broad_stack_mgr.c(2394) 945 %% There has been consecutive 50 mis-matches between driver stack db and app db. Discovery will not be kicked-off."
<13> Jan 2 23:44:43 CORE01-2 DOT3AD[dot3ad_core_lac]: dot3ad_lac.c(290) 918 %% POESW07 is up."""
<14> Jan 2 23:44:43 CORE01-2 DOT3AD[dot3ad_core_lac]: dot3ad_db.c(951) 917 %% Interface 2/0/9 attached to POESW07."""
<13> Jan 2 23:44:43 CORE01-2 DOT3AD[dot3ad_core_lac]: dot3ad_lac.c(290) 916 %% POESW05 is up."""
<14> Jan 2 23:44:43 CORE01-2 DOT3AD[dot3ad_core_lac]: dot3ad_db.c(951) 915 %% Interface 2/0/7 attached to POESW05."""
<13> Jan 2 23:44:42 CORE01-2 TRAPMGR[trapTask]: traputil.c(753) 914 %% Link Up: 2/0/9"""
<14> Jan 2 23:44:42 CORE01-2 SSLT[ssltTask]: sslt_util.c(796) 912 %% SSLT: Successfully loaded all required SSL PEM files"
<13> Jan 2 23:44:42 CORE01-2 BSP[intDisTask]: cpu_boxs.c(2208) 907 %% SFP Interrupt received on the unit 2"""
<13> Jan 2 23:44:42 CORE01-2 TRAPMGR[trapTask]: traputil.c(753) 909 %% Link Up: 2/0/7"""
<13> Jan 2 23:44:40 CORE01-2 TRAPMGR[dot1s_task]: traputil.c(795) 904 %% Spanning Tree Topology Change Received: MSTID: 0 lag 4 """
<13> Jan 2 23:44:40 CORE01-2 TRAPMGR[dot1s_task]: traputil.c(795) 905 %% Spanning Tree Topology Change: 0, Unit: 1"""
<13> Jan 2 23:44:42 CORE01-2 BSP[intDisTask]: cpu_boxs.c(2208) 906 %% SFP Interrupt received on the unit 2"""
<14> Jan 2 23:44:40 CORE01-2 BONJOUR[bonjourTask]: bonjour_control.c(400) 903 %% Bonjour Responder admin mode enable is already set to the same as requetsed"""
<14> Jan 2 23:44:39 CORE01-2 CLI_WEB[tRpcsrv.01000]: config_script_api.c(1040) 901 %% Configuration script TempTxtConfigScript.scr of length 146 is compressed to 162 of size "
<13> Jan 2 23:44:39 CORE01-2 TRAPMGR[trapTask]: traputil.c(753) 899 %% SFP+ inserted in 2/0/12"""
<14> Jan 2 23:44:39 CORE01-2 TRAPMGR[trapTask]: traputil.c(969) 898 %% bad rc on Send Trap call to registrar_ID 33"
<13> Jan 2 23:44:39 CORE01-2 TRAPMGR[trapTask]: traputil.c(753) 895 %% SFP inserted in 2/0/7"""
<14> Jan 2 23:44:39 CORE01-2 TRAPMGR[trapTask]: traputil.c(969) 894 %% bad rc on Send Trap call to registrar_ID 33"
<13> Jan 2 23:44:39 CORE01-2 TRAPMGR[trapTask]: traputil.c(753) 891 %% SFP+ inserted in 2/0/5"""
<14> Jan 2 23:44:39 CORE01-2 TRAPMGR[trapTask]: traputil.c(969) 888 %% bad rc on Send Trap call to registrar_ID 33"
<13> Jan 2 23:44:39 CORE01-2 TRAPMGR[trapTask]: traputil.c(753) 885 %% SFP+ inserted in 2/0/2"""
<14> Jan 2 23:44:39 CORE01-2 TRAPMGR[trapTask]: traputil.c(969) 880 %% bad rc on Send Trap call to registrar_ID 33"
<13> Jan 2 23:44:36 CORE01-2 TRAPMGR[trapTask]: traputil.c(753) 876 %% Warm Auto-Restart has completed on unit 2."""
<14> Jan 2 23:44:36 CORE01-2 UNITMGR[unitMgrTask]: unitmgr.c(2701) 875 %% Warm Auto-Restart complete on unit 2"""
<13> Jan 2 23:44:36 CORE01-2 TRAPMGR[dot1s_task]: traputil.c(795) 874 %% Spanning Tree Topology Change Initiated: 0, Interface: lag 3"""
<13> Jan 2 23:44:36 CORE01-2 TRAPMGR[dot1s_task]: traputil.c(795) 873 %% Spanning Tree Topology Change: 0, Unit: 1"""
<13> Jan 2 23:44:36 CORE01-2 TRAPMGR[trapTask]: traputil.c(753) 872 %% Entity Database: Configuration Changed"""
<13> Jan 2 23:44:33 CORE01-2 TRAPMGR[boxs Req]: traputil.c(795) 871 %% Temperature state change alarm: Unit Number: 2 Current: Normal, Previous: None"""
<14> Jan 2 23:44:32 CORE01-2 DOT1Q[dot1qTask]: dot1q_outcalls.c(317) 865 %% Bad rc 1 in vlanNotifyRegisteredUsers for registrar 48, DOT1S"
<14> Jan 2 23:44:32 CORE01-2 DOT3AD[dot3ad_core_lac]: dot3ad_db.c(1014) 864 %% Interface 2/0/9 detached from POESW07."""
<13> Jan 2 23:44:32 CORE01-2 TRAPMGR[trapTask]: traputil.c(753) 862 %% Link Down: 2/0/9"""
<13> Jan 2 23:44:32 CORE01-2 TRAPMGR[trapTask]: traputil.c(753) 861 %% Link Down: 2/0/7"""
<12> Jan 2 23:44:32 CORE01-2 PTP_TC[ptpTc]: cnfgr_hw_tally.c(356) 858 %% PTP_TC reported unexpectedly for L2 hardware reconciliation"""
<14> Jan 2 23:44:32 CORE01-2 General[procLOG]: procmgr.c(879) 847 %% Application Started (appmgr, ID = 15, PID = 1893"""
<13> Jan 2 23:44:32 CORE01-2 General[procLOG]: procmgr.c(2515) 800 %% Administrative Command:app-start appmgr """
<14> Jan 2 23:44:31 CORE01-2 General[procLOG]: procmgr.c(3756) 798 %% Application Terminated (netsnmp, ID = 3, PID = 1887"""
<14> Jan 2 23:44:31 CORE01-2 General[procLOG]: procmgr.c(879) 799 %% Application Started (netsnmp, ID = 3, PID = 1889"""
<13> Jan 2 23:44:31 CORE01-2 IP[tRpcsrv.02000]: ip_api.c(8998) 797 %% OSPF instance completed NSF routes update."""
<13> Jan 2 23:44:31 CORE01-2 IP[ipMapProcessing]: vrf_util.c(1563) 796 %% Registered IPMAP-0 as a best route callback with RTO"""
<13> Jan 2 23:44:31 CORE01-2 General[procLOG]: procmgr.c(2538) 787 %% Administrative Command:app-restart netsnmp """
<14> Jan 2 23:44:30 CORE01-2 DOT1Q[dot1qTask]: dot1q_outcalls.c(317) 772 %% Bad rc 1 in vlanNotifyRegisteredUsers for registrar 48, DOT1S"
<12> Jan 2 23:44:31 CORE01-2 PVT_GROUP[nim_t]: cnfgr_hw_tally.c(356) 778 %% PRIVATE_GROUP_VLAN reported unexpectedly for L2 hardware reconciliation"""
<13> Jan 2 23:44:30 CORE01-2 DOT3AD[dot3ad_core_lac]: dot3ad_lac.c(290) 767 %% POESW10 is up."""
<14> Jan 2 23:44:30 CORE01-2 DOT1Q[dot1qTask]: dot1q_outcalls.c(317) 771 %% Bad rc 1 in vlanNotifyRegisteredUsers for registrar 48, DOT1S"
