Morpheus187
Jul 06, 2018Aspirant
M4300-24X24F Temperature
Hi There
We got 2 M4300-24X24F Core Switches in a stacking configuration and I'm observing a rather high temperature on those devices.
They operate in a climate controlled room, they have...
- Jul 06, 2018
Hi Morpheus187
No worries, you're well within the spec for longest MTBF here. Intelligent fans and sensor don't trigger more fan speed to keep the noise at low level, without impacting MTBF at all. Internal components were selected for their temperature range.
If temperature goes up (above 25 degrees C), then fans will be triggered, accordingly.
LaurentMa
Jul 06, 2018NETGEAR Expert
Hi Morpheus187
- Morpheus187Jul 07, 2018Aspirant
Thanks for clarification. Then I just don't worry anymore about it.
I just nearly burned my fingers pulling out an SFP+ module but I guess thats normal then :)
