goomisch
Jul 26, 2024Initiate
M4300-24X24F UI problem
Hello Everyone, I have a problem with UI on the switch. AVUI is working but if I try to switch to MainUI - it not works. Switch configuration (WABAGSWDC001) #show ip http HTTP Mode (Unsecure)....
RennaD
Aug 13, 2024NETGEAR Moderator
Hi goomisch,
Welcome to the NETGEAR Community! 🙂
The Main UI is not accessible because the HTTP is disabled and HTTPS is probably not configured properly. To re-enable HTTP type the command "ip http server" on the CLI Privileged EXEC mode.
example:
(WABAGSWDC001)# ip http server
Have a lovely day,
RennaD
Netgear Team
- goomischAug 24, 2024Initiate
Problem solved. It was a firewall issue, after policy update everything work correct. Not allowed port 49151-49152 from vpn to subnet.
