OnanBane's avatar
OnanBane
Follower
Sep 16, 2022
M4300 48x not detecting certain devices
Hi all smart ppl!
I wonder if someone could explain to me what I’m doing wrong. My switch doesn’t detect certain devices when plugged in. I’m Running a Netgate 6100 firewall with multiple vlans and dhcp servers on them. All devices are then connected through my M4300 48x. All my computers get the expected ip when connected to the switch and the firewall rules between the vlans work as they should. The TV works and gets an ip (IoT net), the vacuum gets an ip, the cameras etc...
BUT
When I connect for example my heating pump, my Plejd gateway or my RCO access system (doors, locks etc.) none of those devices are recognized as connected by the switch. No link led and the device list says no device. If I connect them directly to the firewall everything works. I’ve tried different ports with different vlans assigned to them but the switch won’t detect the devices.
Anyone with an idea?
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    OnanBane,
    Welcome to the community! 🙂
    Is everything working fine before?
    What is the current firmware version of the M4300-48X switch?
    It might be possible that your heating pump, RCO access system, etc., are not VLAN capable.
    DaneA
    NETGEAR Community Team
  • schumaku's avatar
    schumaku
    Certain 10/100 Mbps Ethernet devices and 10 GbE PHY can behave odd or fail to establish a workable Ethernet link. Workaround is adding a small eg. unmanaged 10/100(/1000) Mbps in the data path.
ProSupport for Business
