scolson
Jun 28, 2017Follower
M4300-52G ProSAFE 4G24725T000C6 force speed 1G
Hi, I have a stack of 6 M4300-52G I try to force a port 1G in a 1G speed when I try in cli I have the choise of 10mb 100mb and 10G it's not a 10G port you can see a print screen of the cli...
TCan
Jun 28, 2017Aspirant
My guess would be that you don't have that as a choice as it is the default speed.
If you have a piece of equipment that you believe is 1Gb but connecting at a lower speed then I would try another cable as a faulty cable will cause this issue (assuming you have checked the settings on the other equipment and it isn't faulty). Also check there is no damage to the ethernet ports.
