colinauger
Sep 17, 2018Aspirant
M4300-52G ProSAFE InterVLAN Routing
Hello,
I have a really simple setup here, a working stack with tree 4300 prosafe M4300-12X12F, M4300-52G and M4300-28G. each one with the last firmware 12.0.7.7
I have two vlan : vlan 30 (192...
- Retired_MemberSep 20, 2018
Hi colinauger
Ok, I got your requirement.
Currently, you only face one problem:
when workstation on Vlan30, only can ping VM1, but cannot ping VM2;
but when workstation on Vlan40, both can ping VM1 and VM2, right?
Could you please double check as below step:
1. From VM1, check ping 192.168.4.254 and 192.168.3.254;
2. From VM2, check ping 192.168.4.254 and 192.168.3.254;
colinauger
Sep 19, 2018Aspirant
Hi EricZ,
Thx for your help! I certainly misanderstand key concept here.
this our network :
1. VLAN30 IP address of switch. = 192.168.3.254
2. VLAN40 IP address of switch. = 192.168.4.254
3. As you say, DHCP Server(192.168.3.254 and 192.168.4.254) of VLAN30 and VLAN40 is working as Gateway role, right? No, (see attached file) I use two dhcp server for each subnet but they are note the gateway of the subnet. I dont want to use them as gateway to avoid traffic bottleneck. On On vlan 30, it is the internet gateway, the switch default route.
from the workstation01, I ping vm1 (192.168.4.22) but not vm2 (192.168.4.21). Vm1 et vm2 are stricly identical. Of course, if i put a workstation on the vlan40, i can ping vm1 and vm2.
Retired_Member
Sep 20, 2018Hi colinauger
