skypilot65
Mar 19, 2023Aspirant
M4300-52G VLAN Setup with 12.0.17.10
I have acquired a new switch and after downloading and installing the latest FW (12.0.17.10) the directions I located for creating VLANs apparently are for previous FW versions (https://kb.netgear.co...
schumaku
Mar 19, 2023Guru - Experienced User
Using and managing is very similar for all v12.x M4300 models, start for example https://www.netgear.com/support/product/M4300-52G-PoE-Plus%201000W%20PSU.aspx#docs
- skypilot65Mar 19, 2023Aspirant
I appreciate the response. However, what I'm saying is that the documentation that I can currently see and what you pointed me too does not reflect the latest FW version (12.0.17.10).
This is the OLD web portal interface:
This is the NEW interface (FW 12.0.17.10):
Where is the documentation that is for the NEW interface that describes how to setup VLANs?
- schumakuMar 19, 2023Guru - Experienced User
What you define as the new UI is the AV-UI, while the normal Main-UI is retained.
Perfect. How do I get to the main-UI because the AV-UI is the only thing that shows up? Thanks!
