skypilot65
Mar 19, 2023Aspirant
M4300-52G VLAN Setup with 12.0.17.10
I have acquired a new switch and after downloading and installing the latest FW (12.0.17.10) the directions I located for creating VLANs apparently are for previous FW versions (https://kb.netgear.co...
skypilot65
I appreciate the response. However, what I'm saying is that the documentation that I can currently see and what you pointed me too does not reflect the latest FW version (12.0.17.10).
This is the OLD web portal interface:
This is the NEW interface (FW 12.0.17.10):
Where is the documentation that is for the NEW interface that describes how to setup VLANs?
schumaku
Mar 19, 2023Guru - Experienced User
What you define as the new UI is the AV-UI, while the normal Main-UI is retained.
- skypilot65Mar 19, 2023Aspirant
Perfect. How do I get to the main-UI because the AV-UI is the only thing that shows up? Thanks!
Figured it out. Thanks!
