skypilot65
Mar 19, 2023Aspirant
M4300-52G VLAN Setup with 12.0.17.10
I have acquired a new switch and after downloading and installing the latest FW (12.0.17.10) the directions I located for creating VLANs apparently are for previous FW versions (https://kb.netgear.co...
schumaku
Mar 19, 2023Guru - Experienced User
What you define as the new UI is the AV-UI, while the normal Main-UI is retained.
skypilot65
Perfect. How do I get to the main-UI because the AV-UI is the only thing that shows up? Thanks!
- skypilot65Mar 19, 2023Aspirant
Figured it out. Thanks!
