MarsKeeper
Nov 30, 2020Aspirant
M4300-96X occasional packet loss
We have 18 devices connected to the M4300-96X with PoE mode, the devices are kept running always. However, we found there are occasional packet loss, the probability is about one packet loss every three days. We prefere to regard it as normal. However, we want to get more technical explanation:
Is there any relevant standard define the requirement of the PLR (packet loss rate) on 10GbE network?
Packets are not lost in the switch - much more on the links. Typical cause for packet loss are bit errors, caused by poor SNR, insufficient power allocation on an optical link, insufficient link bandwidth, jitter, baseline wander, ..
By wally brain, IEEE states 1*10^-10 for the acceptable BER on a 1000M link. Some discussions were around on 1x10^-13 for the acceptable BER on 10G links.
LaurentMa do you have any more information at hand?
- MarsKeeperAspirant
Hi Schumaku:
Thanks for your reply!
I still have some addtional questions:
1. In the experiment, the devices are powered by PoE mode and it seemed that the PoE budget (capacity) is very critical because the PoE MAX indicator lit on occasionally. As the worst situation, some devices even rebooted because the power was not enough.
Do you think the insufficient PoE power may lead error packet on the 10G copper link?
2. Could you tell me the No. of the IEEE specification about the BER? If you do not remember the exact No. a rough range would be helpful for us.
Thanks!
MarsKeeper wrote:1. In the experiment, the devices are powered by PoE mode and it seemed that the PoE budget (capacity) is very critical because the PoE MAX indicator lit on occasionally.
What kind of PoE devices are we facing here? Any tech data or references available?
For completeness, provide the config (modules, power supplies) of the M4300-96X please.
MarsKeeper wrote:As the worst situation, some devices even rebooted because the power was not enough.
If the device powered does not get enough power (e.g. when it's exceeding the negotiated and speced power) anything can go wrong with the clients... This might have an impact on the 10G link. Crash recovery is the worst case happening.
MarsKeeper wrote:2. Could you tell me the No. of the IEEE specification about the BER? If you do not remember the exact No. a rough range would be helpful for us.
Hm by rule of old cells 802.3ab for Gigabit Ethernet .. don't shoot me 8-)
