JBultman
Jan 24, 2025Follower
M4300-96X REST API - Issue Querying Ports 65-96
Since I still have not received a response to the support email I sent over a week ago, I figure I will ask the same questions here in hopes of getting some answers.
I have been working on a script for Q-Sys to interface with the REST API on an M4300-96X switch. My script is able to connect and query port information for the first 64 ports on the switch but attempting to query information for ports 65-96 results in an “Invalid portid” error.
Why does the API appear to ignore the ports in modules 9-12?
Also, the “sw_portstats” and “swcfg_poe” commands do not appear to accept “ALL” as a portid value even though the REST API reference manual claims it should work. Is there a newer version of the manual with a more accurate command list? I am using the December 2020 version of the document #207-10252-01 which lists API version 2.0.0.59.
The switch is running firmware version 12.0.19.4
I have no modules installed in the first four slots, an APM408C module in slot 5, an APM408F module in slot 6, and APM402XL modules in slots 7-12 running in 4x10Gig expanded port mode.
No RepliesBe the first to reply
