msi
Apr 30, 2020Luminary
M4300: Any way to check for divergence between startup-config and running-config?
Hi I've tried to find a away to identify if the running-config has actually - and if possible what exactly - has diverged compared to the startup-config. It can also be useful to quickly learn if...
- Apr 30, 2020
Hi msi
Thank you for your message, you are right we don't have this command, as of yet. Good input, and (coincidence) we are working on such a new way of comparing a running config with the startup config (and also the backup config saved elsewhere in the flash). There is no ETA yet, still experiment as I speak, we may use other forms of commands/interface for it.
For now, the solution would be the following:
- Copy out ‘startup.cfg’ to your PC
- Copy ‘running.cfg’ to ‘backup.cfg’ on the switch
- Copy out ‘backup.cfg’ to your PC as ‘running.cfg’
- Then use Notepad++ to compare startup.cgf and backup.cfg on your PC
Notepad++ is a great tool that allows just that
(copy from the internet below)
Compare Two Files Using Notepad++
Begin by opening the Plugin Manager from the Plugins menu: Next select the Compare plugin and click Install: Now open both of the files you would like to compare as two separate tabs in Notepad++. Then from the Plugins menu select Compare -> Compare (or use the shortcut Alt+D)
I hope this helps,
Regards
LaurentMa
Apr 30, 2020NETGEAR Expert
Hi msi
I hope this helps,
Regards
