knarfer
Jul 11, 2019Aspirant
M4300 firmware update 12.0.7.15 WAC720 unusable
Hi, i update one of my 4300 switches. On that switch there are 2 wireless access points (WAC-720) connected. The access points are connected to a controller WC7600. after the update the 2 AP's ...
DaneA
Jul 11, 2019NETGEAR Employee Retired
Is the M4300 switch the DHCP server for the 2 WAC720? If yes, kindly configure the DHCP server on the M4300 switch for the 2 WAC720 and check if the same problem will occur.
Check page 93-97 of the M4300 user manual here on how to configure DHCP Server Settings.
DaneA
NETGEAR Community Team
- knarferJul 11, 2019Aspirant
Dane,
the switch is not dhcp server. also the ap's have a fixed ip address.
regards
frank
- DaneAJul 11, 2019NETGEAR Employee Retired
Are the 2 WAC720 still in the managed list of the WC7600? If not, run the discovery wizard on the WC7600 to find and the access points back to the managed list. Kindly read page 155 of the WC7600 user manual here about Discover & Manage Access Points.
DaneA
- knarferJul 12, 2019Aspirant
the problem is not to discover or connect the devices. My concern is that when i update my other switches that i have the same problem.
all the switches are in production. is there a known problem with this update or can we track the logs on the wac720 to see whats the problem with this update so we can prevent this problem on the other switches?
