knarfer
Jul 11, 2019Aspirant
M4300 firmware update 12.0.7.15 WAC720 unusable
Hi, i update one of my 4300 switches. On that switch there are 2 wireless access points (WAC-720) connected. The access points are connected to a controller WC7600. after the update the 2 AP's ...
knarfer
Dane,
the switch is not dhcp server. also the ap's have a fixed ip address.
regards
frank
DaneA
Jul 11, 2019NETGEAR Employee Retired
Are the 2 WAC720 still in the managed list of the WC7600? If not, run the discovery wizard on the WC7600 to find and the access points back to the managed list. Kindly read page 155 of the WC7600 user manual here about Discover & Manage Access Points.
DaneA
NETGEAR Community Team
- knarferJul 12, 2019Aspirant
the problem is not to discover or connect the devices. My concern is that when i update my other switches that i have the same problem.
all the switches are in production. is there a known problem with this update or can we track the logs on the wac720 to see whats the problem with this update so we can prevent this problem on the other switches?
- DaneAJul 14, 2019NETGEAR Employee Retired
I understand. However, since the WAC720 access points are being managed by the WC7600, we need to double check that the WAC720 access points are still within the managed list of the WC7600.
As far as I have checked, there is no issue logged as per described in your initial post. For the logs to be checked, I suggest you to open a support ticket with NETGEAR Support here at anytime.
DaneA
