maindriver
Nov 26, 2021Apprentice
M4300 firwmare 15.4 gone from the website?
Hi, Is there a reason this FW has been removed? We've upgraded about 25 switches to this FW. Some of which reboot as soon as the FW is uploaded, others wait for us to hit reboot. This is ho...
LaurentMa
Nov 29, 2021NETGEAR Expert
Hi Olivier421 ,
We are encountering several issues, mainly stability issues with units in the stack rebooting. We have removed this firmware from the publc website and we are working actively on a fix before reposting this maintenance release. It seems it pertains to the 1G models (GSM series in M4300, mainly). 10G models (XSM series) seem not impacted. Again, we should revert to previous firmware when possible, until we come up with a fix and new maintenance release for 12.0.15.x
wr_ex
Dec 14, 2021Aspirant
We have had it on a 10G XSM only stack. It's a 4 x XSM4348S stack with ver 12.0.15.4. Random reboots/warm restarts of individuals in the stack. Can be 2 or more weeks apart. Other units in the stack will then reboot within 24 hrs and the whole stack becomes unresponsive and requires a full power cycle.
- Olivier421Dec 14, 2021Aspirant
wr_ex Before the 1st issue reboot/stuck happened, what was your uptime of your m4300 24x24f ?
- wr_exDec 14, 2021Aspirant
Less than 4 hrs the first time, and then approx 48 hrs the second time, then the final time 45 days.
- msiJan 23, 2022Luminary
Thanks for posting a banner in the M4300 downloads section, that definitely helps avoid anyone else stumbling into this trop. Please keep us posted on the progress, it seems like a "not so easy" bug considering a 12.0.15.x could not be re-released that easily with "just"[1] the other fixes except for the change that eventually lead to said crashes.
[1] I am fully aware that sometimes "simply" identifying the source of the problem can be one of the hardest things.
