ALNO's avatar
ALNO
M4300 LLDP not transmitted
Hello,
I'm trying to setup a simple LLDP test on one of my device, but it seems that M4300 switch is not sending its own information.
However it receives correctly peer LLDP information.
Here is my configuration on Netgear :
(M4300-28G) #show running-config interface 1/0/13
!Current Configuration:
interface 1/0/13
description 'OneVoip30, gigEth 1/0'
switchport mode access
switchport access vlan 1801
exit
(M4300-28G) #
Show :
(M4300-28G) #show lldp remote-device detail 1/0/13
LLDP Remote Device Detail
Local Interface: 1/0/13
Remote Identifier: 837
Chassis ID Subtype: MAC Address
Chassis ID: 70:FC:xxxxxx
Port ID Subtype: Interface Name
Port ID: ge.589824
System Name: dut_machine
System Description: ONEVOIP VEB-XS, OneOS-pCPE-ARM_pi2-6.2.ci (2018-11-14 08:05:56)
Port Description: GigabitEthernet 1/0
System Capabilities Supported: bridge, router
System Capabilities Enabled: router
Management Address:
Type: IPv4
Address: 192.168.2.26
Time to Live: 120 seconds
(M4300-28G) #show lldp local-device detail 1/0/13
LLDP Local Device Detail
Interface: 1/0/13
Chassis ID: B0:B9:xxxxx
Port ID Subtype: Local
Port ID: 1/0/13
System Name:
System Description: M4300-28G ProSAFE 24-port 1G and 2-port 10GBASE-T and 2-port 10G SFP+, 12.0.0.15, 1.0.0.7
Port Description: OneVoip30, gigEth 1/0
System Capabilities Enabled: bridge, router
Management Address:
Type: IPv4
Address: 172.25.0.175
(M4300-28G) #
(M4300-28G) #show lldp statistics 1/0/13
LLDP Device Statistics
Last Update.................................. 0 days 00:41:30
Total Inserts................................ 837
Total Deletes................................ 1
Total Drops.................................. 0
Total Ageouts................................ 92
Tx Rx TLV TLV TLV TLV TLV TLV
Interface Total Total Discards Errors Ageout Discards Unknowns MED 802.1 802.3 UPOE
1/0/13 0 83 0 0 0 0 0 0 0 0 0
(M4300-28G) #
The statistics indicates that M4300 didn't send any frame to the other device
What can I do ?
Thank you
  • Ok, nevermind, after a hard reboot of netgear it works
    • ALNO's avatar
      ALNO
      Ok, I'm coming back because I have still issues with LLDP.
      After 15h of no issue, I found this morning that LLDP is still stalled. I had to issue a "reload" on CLI to make it work again.
      Is this a known issue ?
      • LaurentMa's avatar
        LaurentMa
        NETGEAR Expert
        Hi ALNO
        Sorry about that and no, there is no known issue with LLDP on our M4300's. It means we have interoperability issue in your network and we need to understand what is the root cause to fix it together.
        Now that you have reloaded the switch, please wait 15 hours or so until you see the issue happening again. Then when the issue is visible, please export the Tech Support file out of the switch and send it to us via Private Message. In this file, our Tech Support and Engineering teams will find everything they need to troubleshoot. It is basically a collection of show and debug commands.
        How to get the Tech Support file from your NETGEAR M4300 managed switch:
        • First, please log in to the command line interface of the switch, and from enable mode, run the command: show tech-support. When done, you can proceed with the CLI method or the Web GUI method below.
        • Using CLI, you can use the COPY command, the file to copy is <<nvram:tech-support>>.
        • Using the Web GUI, you can upload the Techsupport file by selecting Select Maintenance > Export > HTTP File Export.
ProSupport for Business
