boe
Apr 21, 2025Luminary
M4300 POE - not powering devices
I have a stack of M4300 switches. I have not changed their configuration in nearly a year. The power for the building goes out about ever few months. Once in a while you have to manually power the sw...
schumaku
Apr 26, 2025Guru - Experienced User
boe wrote:
This last reboot had a different issue the POE in switch 4 doesn't seem to work - it shows in the web interface. PCs work. It says power is turned on but phones and cameras do not work. The GUI shows "requesting power" for the phones but never changes to "delivering power" I've already rebooted - any other suggestions?
Contact Netgear Customer support via https://my.netgear.com/ - most likely a broken PoE module or subsystem - to you got your life time warranty replacement of that failed M4300 switch..
