ClemensD
May 31, 2018Tutor
M4300 Stack - issues with packet loss and management performance
Hello,
we are using 3 M4300-24x24f as a core unit working in stack mode.
The stack is configured with 2 uplinks to each device (2*10GB) as a ring.
Currently, and i don´t know when it occured first, we have the following effects:
- ping loss about 30% from all network neigbors to the core (ping, ssh, web management)
- cpu usage about 65%
- local management connects like usb or console are not affected
The network load is not dealing with high numbers.
After a while of thinking about the stack itself could cause this behaviour.
What kind of options we have to determine these issues?
Best,
Clemens
1 Reply
- DaneANETGEAR Employee Retired
Hi ClemensD,
Is your concern is related to your post way back a few months ago?
It seems that the tech Support file will be needed to check why the problem occurs. I suggest you to open a chat or online case with NETGEAR Support at anytime then let them know about your concern for troubleshooting.
DaneANETGEAR Community Team
