Greg_11
Mar 03, 2017Aspirant
M4300 stacking problems
I'm trying to create an 8 switch spine and leaf stack with two XSM4324S (M4300-12X12F) and six GSM4352PB-100NES (M4300-52G-PoE+) and I'm having some major issues. The stack created fine with 7 of the...
DanielZhang
Mar 07, 2017NETGEAR Expert
Hi Greg,
Welcome to NETGEAR community!:smileyhappy:
Could you share us the simply topology about the spine and leaf stack?(the stack port connected between spine and leaf)
Which SFP+ module did you used for stack? (or DAC cable?)
Did you set the high stack priority for both spine switch? (It will make two M4300-12X-12F as master and standby all the time)
Please also send the diagnosis information to us as following link:
http://kb.netgear.com/app/answers/detail/a_id/31439
- Greg_11Mar 07, 2017Aspirant
Hi again Dainel,
The stack ports of the two 12x12f switches are set to Management and OprStandby with priority 15 and 14 respectively. All of the PoE switches have undefined priority and are Stack Members. The switches are connected with either DAC, CAT6 (to stack ports), SMF, or MMF. The DACs and all transcievers are NETGEAR compatible from FiberStore. Diagram below. The switches that aren't stacking properly are Access-7 and Access-8. I'll get the diagnostic files uploaded shortly. Access-8 is not currently connected to the stack as I need the devices connected to it uplinked to our network. Currently the access stack shown is uplinked to our existing core switch (not shown) during transition.
I just noticed.. On the diagram, the uplinks from the CORE stack to the firewall are only 1G, not 10G even though the legend says it all is.
- DanielZhangMar 08, 2017NETGEAR Expert
Hi Greg,
I suggest you to upgrade the M4300 to latest firmware before we continue troubleshooting this case.
You can find the firmware from following link:
M4300 Firmware Version 12.0.2.10
I also have some question and suggestion for you.
1. The port link between stack_1 and stack_2 should be Ethernet mode not the Stack mode.
(I can't see the LAG configure on master/standby.)
2. Could you share us the techsupport file on stack_2?
