WojtekC
Jun 16, 2019Guide
M4300 VLAN routing interface gets down with stack master
My simplified lab setup is two M4300-12X12F, stacked up. All ports, except stack ones, are set as follow: interface x/x/x
switchport mode trunk
vlan acceptframe vlanonly
vlan ingressfilter
exit
T...
- Jun 16, 2019
I've have some issues on a mixed stack of 1x M4300-12X12F (same as yours) and a M4300-52G-PoE+ with this firmware version where initiating a failover between master and standby master (configure; stack; initiate failover) would render a stack management inaccessible. Although not exactly the same thing, a manual failover or a power off event on the master leads to the same situation where the standby master will take over the stack master role.
Could you check that when you initiate a failover like me that the new master has some ports in DETACH state when you issue the 'show port status all' command? If you lose access over SSH, try the serial console, it remained working in my situation.
I'm currently working with Netgear on an issue with this specific version and testing a beta release after they have done some preliminary testing internally. I don't do any inter-VLAN routing on the M4300's so my use case is not entirely compareable to yours, additionnaly this only happened on that mixed stack but not on another stack with 2 M4300-52G-PoE+'s.
If you see the same behaviour load 12.0.7.10 into the other firmware bank and start it. In my case failover was still rather slow and causing some packet loss, but overall working. If things are similar I could send you my case number in private so you could point the Netgear support to potentially give you access to that release. (I am not permitted to do so by the beta agreement which I had to accept for this support case)
WojtekC
Jun 16, 2019Guide
When I've tried "reset" interface as follow:
configure interface vlan 3 no ip address exit exit vlan database no vlan routing 3 vlan routing 3
got message:
../../../../andl/hapi/esw/switching/broad_l2_std.c 3095: In hapiBroadAddrMacAddressEntryAdd call to 'bcmx_l2_addr_add' - FAILED : -6
Despite message I'm going on with:
configure interface vlan 3 ip address x.x.x.x /x
ending with interface set up properly, but still down.
WojtekC
Jun 16, 2019Guide
Errata:
Desoite -> Despite
proberly -> properly.
Sorry, I'll try remember use spellchecker button next time.
- WojtekCJun 16, 2019Guide
Couple minutes after turning on former stack master:
Trying to attach more units..... RPC - Timeout to CPU: xx:xx:xx:xx:xx:xx. ATP: TX timeout, seq 7. xx:xx cli 778. to 1 tx cnt 21. ATP: TX timeout, seq 122. xx:xx cli 780. to 1 tx cnt 21. ATP: TX timeout, seq 59. xx:xx cli 8. to 1 tx cnt 21. ATP: TX timeout, seq 8. xx:xx cli 778. to 1 tx cnt 21. ATP: TX timeout, seq 124. xx:xx cli 780. to 1 tx cnt 21. RPC - Timeout to CPU: xx:xx:xx:xx:xx:xx. disc ERR: Timeout occurred l7_usl_bcmx_l3.c:369 : USL: error creating L3 interface for mac xx:xx:xx:xx:xx:xx vid 1: VrfId 0: hwRv=-8 dbRv = 0 L3 interface create failed because the MAC Address is already present. Please try again later l7_usl_bcmx_l3.c:369 : USL: error creating L3 interface for mac xx:xx:xx:xx:xx:xx vid 3: VrfId 0: hwRv=-8 dbRv = 0 L3 interface create failed because the MAC Address is already present. Please try again later
Despite that message both units work fine in layer 2, as far as I can verify.
But VLAN 3 ip interface is still down (VLAN 1 also, but I not use it, so dont care).
