WireJunkie
Aug 22, 2022Tutor
M4300 with latest firmware. DHCP Snooping NOT working
we have a 4352pa switch with a strange issue, we setup server 2019 dhcp on port 5 and configured port for dhcp snooping as per instructions found on netgear website. After enabling Port 5 as the DH...
DaneA
Aug 23, 2022NETGEAR Employee Retired
What is the current firmware of the M4300-52G-PoE+ (GSM4352PA) switch? If ever its not yet the latest version, I suggest you to update it then check if the same problem will occur. The latest M4300 firmware is v12.0.17.7 and you can download it here.
DaneA
NETGEAR Community Team
DaneA
Aug 24, 2022NETGEAR Employee Retired
How is everything connected? Kindly post an image of your detailed network setup.
DaneA
- WireJunkieAug 24, 2022Tutor
On the M4352 switch, DHCP Snooping is setup as follows:
Firewall is acting as internet Gateway and providing DHCP. So the setup is Firewall (LAN)--->Port 5 on switch. All PCs are on VLAN1
For example, we put computers on ports 31 and 32.
We enabled the following on the Switch.
DHCP Snooping MODE ON
MAC Validation ON
For the VLAN ID 1 and Enabled
For DHCP Snooping Interface Configuration, Port 5 is selected and Trust ENABLED.
After doing that, none of the PC's receive DHCP. Doing the same steps on a GSM7224 it works with DHCP Snooping.
