WireJunkie
Aug 22, 2022Tutor
M4300 with latest firmware. DHCP Snooping NOT working
we have a 4352pa switch with a strange issue, we setup server 2019 dhcp on port 5 and configured port for dhcp snooping as per instructions found on netgear website. After enabling Port 5 as the DH...
DaneA
Aug 24, 2022NETGEAR Employee Retired
How is everything connected? Kindly post an image of your detailed network setup.
DaneA
NETGEAR Community Team
WireJunkie
Aug 24, 2022Tutor
On the M4352 switch, DHCP Snooping is setup as follows:
Firewall is acting as internet Gateway and providing DHCP. So the setup is Firewall (LAN)--->Port 5 on switch. All PCs are on VLAN1
For example, we put computers on ports 31 and 32.
We enabled the following on the Switch.
DHCP Snooping MODE ON
MAC Validation ON
For the VLAN ID 1 and Enabled
For DHCP Snooping Interface Configuration, Port 5 is selected and Trust ENABLED.
After doing that, none of the PC's receive DHCP. Doing the same steps on a GSM7224 it works with DHCP Snooping.
