WireJunkie
Aug 22, 2022Tutor
M4300 with latest firmware. DHCP Snooping NOT working
we have a 4352pa switch with a strange issue, we setup server 2019 dhcp on port 5 and configured port for dhcp snooping as per instructions found on netgear website. After enabling Port 5 as the DH...
DaneA
Sep 01, 2022NETGEAR Employee Retired
Kindly post screenshots of the configuration you have made on the M4300-52G-PoE+ (GSM4352PA) switch as well as the configuration you have made on the GSM7224.
Kindly attached also the tech support file from both switches.
DaneA
NETGEAR Community Team
