Onyx_Z
Apr 27, 2021Follower
M4300-x24 OVERHEATS and runs WAY too hot. Need internal fan speed increase
We have 8 x M4300-24x switches. They work great! great performance, BUT they constantly run around 68 degrees Celcius. WAY WAY too hot. We've had to return 4 of them for replacment because they burn up. Checking the system environment info, it says the internal fans are ONLY running at 17%. WHY?? If we could crank these up to 50% or 75% it would probably get all that HOT air out of the system, and stop them from burning up. They are in a cooled computer room, so noise is NOT an issue. I thought I saw some community post where they said there WAS a patch to increase the fan speed. HOW do I get a hold of this before we burn up MORE of our units? Please help!
- Matthew_mAspirant
Hi, could you post the result of any "fixes" as we have this same issue and been around with support and various other netgear folk and not yet found a solution (we have lost 12 units to date).
