sblair
May 20, 2019Aspirant
M4300/M4200 Inter-VLAN routing not over default gateway
I'm having some issues working out Inter-VLAN routing. I've doing a simple test config with 2 VLANs (80 and 90) and trying to ping between 1 device located on each VLAN. My routing IP's in the swit...
sblair
May 21, 2019Aspirant
Ignore the "over default gateway" part of the subject above. It auto-suggested that from previous topics and didn't realized it entered that (I had already read through all of those hoping to find my answer but didn't....)
Thanks
Scott
- schumakuMay 21, 2019Guru - Experienced User
Still, we talk of a static IPv4 routing environment. There is no "magic" inter-VLAN routing. So either the two test systems have the connected VLAN-IP as the default gateway, or the effective default gateway has working static routes to the other subnet. Based on the switch config only, we can just guess.
- sblairMay 21, 2019Aspirant
If you could provide some better guidance it would be appreciated. I'm trying to test this in a sandbox network here. In some cases I'll have a gateway connection from this switch to the internet, in many cases I won't. I'm looking for how to use the L3 features of the switch so that I can establish routing between the two VLANs whether I have an external gateway present or not...
In this case the direct connected VLAN IPv4 address must be the default gateway configured on the connected systems.
The "Inter-VLAN" routing does not work on some dynamic or protocol analysis - it must be configued on all systems properly.
The system connected to the VLAN with the 192.168.80.0/24 subnet must use 192.168.80.254 for the default gateway.
The system connected to the VLAN with the 192.168.90.0/24 subnet must use 192.168.90.254 for the default gateway.
The point is that the IP stack say on a system with the example IP 192.168.80.123 can either communicate with addresses on the same subnet (so 192.168.80.0/24) - any other traffic will be sent to the default gateway.
The point is that the IP stack say on a system with the example IP 192.168.90.234 can either communicate with addresses on the same subnet (so 192.168.90.0/24) - any other traffic will be sent to the default gateway.
That's static IPv4 routing. Your switch must become a core part of the IPv4 routing. Anything he can't handle then can be sent ahead to the "next hop" gateway, e.g. to the Internet.
