sblair
May 21, 2019Aspirant
M4300/M4200 Inter-VLAN routing not over default gateway
I'm having some issues working out Inter-VLAN routing. I've doing a simple test config with 2 VLANs (80 and 90) and trying to ping between 1 device located on each VLAN. My routing IP's in the swit...
schumaku
May 22, 2019Guru - Experienced User
Scott,
sblair wrote:
There should not be anything else I'm aware of I would need to configure on the client PC's since I do have proper gateways set.
What is "proper gateway set" in your opinion? If this translates to your common Internet router LAN IP - afraid, then it's wrong, and you have to re-think how static IPv4 routing does work please.
-Kurt
sblair
May 22, 2019Aspirant
Kurt,
As I clearly stated in the last post, each PC has a static gateway set that matches the routing interface of the single switch I have here.
Gateway Config of switch from post #1:
interface vlan 80 routing ip address 192.168.80.254 255.255.255.0 exit interface vlan 90 routing ip address 192.168.90.254 255.255.255.0 exit
And as I said in the last post, the config of the 2 devices are:
PC 1: is in VLAN80. Static IP is: 192.168.80.201 255.255.255.0 192.168.80.254 PC 2: is in VLAN90. Static IP is: 192.168.90.200 255.255.255.0 192.168.90.254
The last set of addresses there is the Gateway IP I set in those devices statically.
As I said before this is a sandbox setup and often will NOT have any connection to the Internet, as is the case with the config right now. There is nothing in the network other than the single L3 switch and the (2) PC's. No gateway connection to the Internet.
I'm just trying to get a ping between 2 devices on different subnets on the SAME swtich.
Thanks.
Scott
- sblairMay 22, 2019Aspirant
Anyone from Netgear that can help answer?
Thanks.
Scott
- CaseyHMay 22, 2019NETGEAR Expert
Scott,
Can you send me the tech-support file from the switch. It looks like you've got things correct but want to see everything to see whats wrong. If you can ping one gateway on the switch you will be able to ping them all, this is just how our switch works. Get me the TS and I'll be able to figure out what we're missing.
Casey H.
Thanks Casey.
Here's the TS file from the M4200. It's a bit more terse in info than the latest M4300 TS files provide.
Here's the routing table for my laptop below too if it helps. All interfaces were disabled except my wired connection. Same on the other laptop. My laptop was in Port 0/4 but I pulled the connection to grab the TS file from the OOB.
I'll email you the TS file directly. It wouldn't let me attach here and was too big to paste the contents into the body.
C:\Users\sblair>netstat -r =========================================================================== Interface List 13...10 65 30 65 0e bb ......Intel(R) Ethernet Connection (7) I219-LM 11...b4 6b fc db 57 8c ......Microsoft Wi-Fi Direct Virtual Adapter 5...b6 6b fc db 57 8b ......Microsoft Wi-Fi Direct Virtual Adapter #2 17...b4 6b fc db 57 8b ......Intel(R) Wireless-AC 9560 160MHz 7...b4 6b fc db 57 8f ......Bluetooth Device (Personal Area Network) 1...........................Software Loopback Interface 1 =========================================================================== IPv4 Route Table =========================================================================== Active Routes: Network Destination Netmask Gateway Interface Metric 0.0.0.0 0.0.0.0 192.168.90.254 192.168.90.200 281 127.0.0.0 255.0.0.0 On-link 127.0.0.1 331 127.0.0.1 255.255.255.255 On-link 127.0.0.1 331 127.255.255.255 255.255.255.255 On-link 127.0.0.1 331 192.168.90.0 255.255.255.0 On-link 192.168.90.200 281 192.168.90.200 255.255.255.255 On-link 192.168.90.200 281 192.168.90.255 255.255.255.255 On-link 192.168.90.200 281 224.0.0.0 240.0.0.0 On-link 127.0.0.1 331 224.0.0.0 240.0.0.0 On-link 192.168.90.200 281 255.255.255.255 255.255.255.255 On-link 127.0.0.1 331 255.255.255.255 255.255.255.255 On-link 192.168.90.200 281 =========================================================================== Persistent Routes: Network Address Netmask Gateway Address Metric 0.0.0.0 0.0.0.0 192.168.90.254 Default =========================================================================== IPv6 Route Table =========================================================================== Active Routes: If Metric Network Destination Gateway 1 331 ::1/128 On-link 1 331 ff00::/8 On-link =========================================================================== Persistent Routes: NoneI assume I'm doing something stupid so I figured I'd post here before pinging you or Alex directly.
Thanks.
Scott
