ITK_Staud
Feb 27, 2017Aspirant
M5300-52G-POE+ // Port does not come up - Port programming failed with error 0x1 for event OPERATION
Hi Community, I have a GSM7252PS switch which worked fine for some months now. Since a few days the 10GBit/s uplink (via SFP AXM761) isn't coming up anymore. We tried - different SFP - differ...
ITK_Staud
Feb 28, 2017Aspirant
Hi Daniel,
thanks for your reply.
Here is the output of the CLI you requested:
(M5300-52G-POE+) #show environment
Temp (C)....................................... 31
Temperature traps range: 0 to 90 degrees (Celsius)
Temperature Sensors:
Unit Sensor Description Temp (C) State Max_Temp (C)
1 1 System 31 Normal 32
Fans:
Unit Fan Description Type Speed Duty level State
1 1 CPU 1 Fixed Not Supported Not Supported Operational
1 2 CPU 2 Fixed Not Supported Not Supported Operational
1 3 Power 1 Fixed Not Supported Not Supported Operational
1 4 Power 2 Fixed Not Supported Not Supported Operational
Power Modules:
Unit Power supply Description Type State
1 1 AC Fixed Operational
1 2 RPS Removable Not present
RPS
Unit Status Power Module RPS Port ID
1 Not present Not present 1
(M5300-52G-POE+) #show fiber-ports optics-info all
Link Link Nominal
Length Length Bit
50um 62.5um Rate
Port Vendor Name [m] [m] Serial Number Part Number [Mbps] Rev Compliance
1/0/49 NETGEAR 8 3 2F71373C06790 AXM761 10300 20 10GBase-SR
1/0/50 NETGEAR 8 3 2F71373C06794 AXM761 10300 20 10GBase-SR
(M5300-52G-POE+) #
(M5300-52G-POE+) #show fiber-ports optics all
Output Input
Port Temp Voltage Current Power Power TX LOS Fault
[C] [Volt] [mA] [dBm] [dBm] Fault Status
1/0/49 26.4 3.264 5.0 -2.351 -2.425 No No No Fault
1/0/50 26.4 3.267 6.0 -2.217 -2.548 No No No Fault
(M5300-52G-POE+) #show fiber-ports optics-eeprom all
Port 1/0/49
vendor_name = NETGEAR
vendor_sn = 2F71373C06790
date_code = 130818
vendor_pn = AXM761
vendor_rev = 20
eeprom data =
03 04 07 10 00 00 00 00 00 00 00 06 67 00 00 00 ............g...
08 03 00 1e 4e 45 54 47 45 41 52 20 20 20 20 20 ....NETGEAR
20 20 20 20 00 00 09 5b 41 58 4d 37 36 31 20 20 ...[AXM761
20 20 20 20 20 20 20 20 32 30 00 00 03 52 00 b9 20...R..
00 1a 00 00 32 46 37 31 33 37 33 43 30 36 37 39 ....2F71373C0679
30 20 20 20 31 33 30 38 31 38 20 20 68 f0 05 12 0 130818 h...
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
Port 1/0/50
vendor_sn = 2F71373C06794
date_code = 130818
vendor_pn = AXM761
vendor_rev = 20
eeprom data =
34 20 20 20 31 33 30 38 31 38 20 20 68 f0 05 16 4 130818 h...
(M5300-52G-POE+) #
I also created a tech-support file which I can send you if like to have it.
Thanks a lot for your help and best regards,
Martin
DanielZhang
Feb 28, 2017NETGEAR Expert
Hi Martin,
Thanks for your feedback.
It really help us to analyze this error logs.
Please also send the TechSupport file to our team as following link.
It will help us to analyze more efficient.
http://kb.netgear.com/app/answers/detail/a_id/31439
- ITK_StaudMar 01, 2017Aspirant
Hi Daniel.
I've sent the TechSupport file as described in the link.
Looking forward to read about your results.
Thanks a lot in advance,
Martin
- DanielZhangMar 01, 2017NETGEAR Expert
Hi Martin,
Our team have received your techsupport file on M5300.
It seems that the XSM7224S connected with M5300.
Could you please also provide the TechSupport file on the peer device XSM7224S?
The same e-mail address will forward the TechSupport file to us.
