WillieEverlearn
Nov 03, 2015Aspirant
M5300 Stacking w/ AX742 kit
Forgive me if this is a question that is answered elsewhere, but I am attempting to stack a couple groups of 4-5 M5300 switches in my school district. Installing the kits is easy enough and I powere...
- Nov 10, 2015
I spoke with NetGear support and he will continue to research, but he suggested that the only solution would be to configure the UPS to power on the master switch first.
DaneA
Nov 04, 2015NETGEAR Employee Retired
Hi WillieEverlearn,
WillieEverlearn wrote:
a. The switches are new, and the stacking kits are newer....this is the only Firmware that we have since installing the stacking kits.
b. By 'reconfigure' do you have any documentation that I could look at? Is there a recommended method of setting up the stack manually?
We simply unplugged the switches, installed the stacking kits, powered switches on in order.
What I mean by 'reconfigure' is setting up the stack, the IP address, VLANS, etc. Kindly try to factory reset the switch/es the reconfigure it from scratch then observe if same problem occurs.
DaneA
NETGEAR Community Team
WillieEverlearn
Nov 10, 2015Aspirant
