NameAlreadyTake
Aug 17, 2022Aspirant
M7100-24X (XSM7224) switch - Power usage and fans
Hi, Please can anyone advise what the power usage in Watts is for this unit is if just plugged in with no traffic load? Also do the fans slow down and speed up with the amount of traffic passing t...
NameAlreadyTake
Aug 18, 2022Aspirant
Thanks JeraldM. Thanks that would be appreciated.
I'm particularly conscious regarding power usage especoally at the moment, but also from a green perspective... There will be a good portion of the day where traffic is minimal so I'm hoping that ultra low data traffic equals ultra low power consumption.
I'm also hoping the unit will not be noisy when there is little traffic as it will be in the room I work in.
Thanks.
Kind regards,
James
Thanks.
Kind regards,
James
JeraldM
Sep 12, 2022NETGEAR Employee Retired
Hi NameAlreadyTake,
Thank you for patiently waiting!
Upon inquiry, the power usage of the M7100-24X doesn't have much of a difference when it's on the idle state compared to its worst case state.
JeraldM
NETGEAR Community Team
