CHOIBORA's avatar
CHOIBORA
Follower
Aug 06, 2019
M7300 POWER 1 LED INDICATED YELLOW STEADY
MODEL NO. is M7300-24XF XSM7224S.
POWER 1 LED is indicated yellow steadily and all of ports LEDs is yellow and STACK Master LED is OFF.
ID is displayed 01(green) and FAN LED is green.
But, this is not operative.
Help me.
1 Reply
  • Hi
    Have a look at the Hardware Installation Guide for your switch model, specifically:
    • Page 6 LED descriptions
    • Page 12/13 Connect to Power and Check the LEDs
    A steady yellow power LED would indicate a ongoing boot process. If you want to know where (and if) your switch has issues or maybe is stuck, I'd recommend connecting a serial console. On these switches the (default) baud rate you need to configure should be written on the front panel, close to the DB9 port for the serial console.
    Hope that helps.
ProSupport for Business
