wwoltmann's avatar
wwoltmann
Managed switch
Is there a 5-port managed switch that will allow me to force gigabit speeds?
  • JohnC_V's avatar
    JohnC_V
    Jul 25, 2018
    wwoltmann,
    Where are you getting that speed? What tools are you using to test it? If you really want to know the throughput of the ports then you may need to use JPerf, bandwidth is different from port speed. NETGEAR doesn't have a 5-port switch that can manually set the port speed to 1G.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
