farjsloan
Sep 18, 2017Aspirant
Manged Switch Trunk Port Light
Sorry if this is a confusing question on my part.... I use a number of Netgear managed switches in a VLAN network. I've noticed that the "trunk" port on the respectively connected switches will ...
Hopchen
Sep 18, 2017Prodigy
Hi,
Your assumption is correct. A trunk port will carry all the traffic, from the various VLANs, across to the next switch/router. Therefore, trunks/uplinks are always the most busy links in the network.
Looking at the port LEDs blinking will give an indication of how busy the port is. If you want to see a more detailed breakdown of the traffic, per port, then log into the Web GUI and navigate to: "Monitoring" --> "Ports" --> "Port Statistics".
Cheers
farjsloan
Sep 19, 2017Aspirant
Thank you :-)
- HopchenSep 19, 2017Prodigy
No problem at all!
Please consider marking this thread as solved.
Cheers
- JohnC_VSep 19, 2017NETGEAR Employee Retired
I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Welcome to our community!
