robfantini
Jul 11, 2017Aspirant
many of these in log "Spanning Tree Topology Change Received"
Hello at Monitoring > lags , lag 11 has had some "Packets received with Errors" . now there are about 20. last week 8 . so I set up logging to go to a rsyslog server . just lag 11 has ...
- Retired_MemberJul 13, 2017
Yes, we have got the detailed info. Thanks for your immediately response.
1. According to the memory log, we found that port 1/0/29 and 2/0/29 is flapping. Could you please double check these two port status?
2. According to spanning tree log, there is loop topo change. Could you please provide the network topo to us for further analysis?
3. I am afraid the traffic wasn't interrupted by these spanning tree log, right? As I think these log is normal, just dut to STP protocol detect topo tree changing, and adjust forwarding path.
Retired_Member
Jul 11, 2017Hi robfantini,
Welcome to the community!
These spanning tree log is due to topo change, please check whether there is port flapping or not in the switch?
Hope it helps!
EricZ
NETGEAR employee
robfantini
Jul 12, 2017Aspirant
Hello
Could you please advise on were to check for 'port flapping or not in the switch '
- Retired_MemberJul 12, 2017
Ok, please send the tech-support file to us. As this file contain more detailed info.
How do I send tech-support files from my Managed Switch to NETGEAR community moderators?
- robfantiniJul 13, 2017Aspirant
OK I just sent what I could AND
Note on my switch there are not options for ' full memory dump ' and ' crash logs ' . In case you have a suggestion for those.
thank you for the help so far!
