robfantini's avatar
robfantini
many of these in log "Spanning Tree Topology Change Received"
Hello   at Monitoring > lags ,  lag 11    has had some "Packets received with Errors" . now there are about 20.   last week 8 .   so I set up logging to go to a rsyslog server .  just lag 11 has ...
  • Retired_Member's avatar
    Retired_Member
    Jul 13, 2017
    robfantini
    Yes, we have got the detailed info. Thanks for your immediately response.
    1. According to the memory log, we found that port 1/0/29 and 2/0/29 is flapping. Could you please double check these two port status?
    2. According to spanning tree log, there is loop topo change. Could you please provide the network topo to us for further analysis?
    3. I am afraid the traffic wasn't interrupted by these spanning tree log, right? As I think these log is normal, just dut to STP protocol detect topo tree changing, and adjust forwarding path.
ProSupport for Business
