tastleford's avatar
tastleford
MFA on managed switches
Hello!
Are there any netgear managed switches that support MFA for the admin login? Our insurance company is requiring it even for INTERNAL access... which, I feel is overkill but.... not my call.
Thanks in advance!
Tawny
  • Hi tastleford,
    Thank you for reaching out to the Community.
    No, we don't support multi-factor MFA for the admin login to the Web GUI or console telnet/ssh. Sorry, I agree, it would be quite a thing.
    Instead, we support management access control (so CPU ACL) to restrict admin login to certain L2/L3 only. Also TACACs is supported for admin login.
    I hope this helps!
  • LaurentMa's avatar
    LaurentMa
    NETGEAR Expert
    Hi tastleford,
    I hope this helps!
ProSupport for Business
