apoling
Jan 23, 2019Aspirant
MIB for GS110TP and GSM7212F
Can I get a download link for the MIB files for GS110TP and GSM7212F?
Thanks, Drew
Hi apoling,
Welcome to our community! :)
Here is the MIB for GS110TP and GSM7212F. No password needed and the link will expire after 48 hour period.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- JohnC_VNETGEAR Employee Retired
Hi apoling,
- apolingAspirant
"Accepted Solution"
-Thanks
