Bael
Dec 04, 2023Aspirant
MKV files don't work with Samsung TV
I recently added the Netgear GS305E switch to my network, for the wired devices in my bedroom. But since doing so I cannot stream MKV files to my Samsung smart tv. MP4 files seem to work fine, but af...
- Dec 04, 2023
No other systems connected to the new installed switch, probably making more load to the DLNA media server?
Time for a factory reset, probably a firmware update? -> https://www.netgear.com/support/product/gs305e
Does not sound like a healthy connection to me.
Should this not fix the issue, head to https://my.netgear.com/ ... select your registered device and follow the [Request Hardware Support]-
schumaku
Dec 04, 2023Guru - Experienced User
Hard to imagine the addition of a GS308E would cause such a problem - assuming there is no misconfiguration.
Where are you connecting the Samsung TV to exactly to play-back these MKV containers, where are these MKV stored?
Bael
The TV is connected to port 1 on the switch and the files are stored on my PC, streamed via media library
