rafrafa
Mar 11, 2020Follower
most reliable switch choosing between M4300-48X and XS748T
I'm currently looking to replace a XS728T and get more ports. I'm considering getting the M4300-48X or a XS748T - besides the management that would allow stacking and more things I try to figure out if the M4300 would bring more performances / reliability over a XS748T.
I'm mainly using lvl2 switching.
Thank you
Rapha
1 Reply
- DaneANETGEAR Employee Retired
One of the differences between the XS748T and M4300-48X is that all 44 ports of the XS748T only supports 1G / 10G of ethernet connection. While the M4300-48X supports 100Mbps / 1Gbps / 10Gbps on all 48 ports. You can compare their specifications through their respective data sheets below:
Also, this article below can help you learn more about the M4300-48X:
NETGEAR ProSAFE® M4300 Intelligent Edge Series Frequently Asked Questions
Furthermore, you can check the links below to know more about the vast variety of NETGEAR Business Switches that might fit your network requirements:
NETGEAR Business Product Catalog Volume 20-1 - see pages 10-59
DaneA
NETGEAR Community Team
