homerfan
Aug 27, 2023Initiate
MS510TXPP Bricked?
Hello, I purchased a secondhand MS510TXPP. When booting it up, the power light was a solid amber which led me to beleived the switch may be bricked. None of the other ports would light up even ...
schumaku
Sep 02, 2023Guru - Experienced User
Try a terminal emu like the legacy Hpyerterm or the Open Source Tera Term via https://ttssh2.osdn.jp/index.html.en (use the GitHub link).
Download the current firmware and unpack the .zip archive.
Start the xmodem upload from the console by using the X, then start upload the firmware image by the xmodem protocoll (currently MS510TX_TXPP_V6.7.0.52.bin).
Good luck, and have fun!
- homerfanSep 02, 2023InitiateThanks for the reply.
That was exactly what I tried. As you can see from the code block in my original message, the file upload completes and then get stuck at u-boot.
I have tried every firmware file on the website. They all upload fine but then get stuck at U-boot.
