Neilio
Jan 09, 2018Aspirant
Multi-gigibit switch and 10GB switch?
Hello, I see that there are some newer multi-Gigabit switches out that work with Smart Control Center, this is great but they are lacking the ability for full 10Gb across all the ports. Do we know ...
schumaku
Jan 15, 2018Guru - Experienced User
Neilio wrote:I do see the other Multigig switch available under the Plus switches (GS110EMX ) but this doesn't work with the Smart Control app and is only 2x 10Gb ports.
Curiosity question: What is the killer feature of this Smart Control Center App?
JohnC_V wrote:NETGEAR has a full 10GB switches which is the 10-Gigabit Smart Managed Pro Switch. This is also compatible to smart control center.
Nothing silent for the desktp and enclosure sizes the OP was asking for, isn't it?
