mayank7489
Nov 02, 2017Aspirant
Multicast stops working after about 20 minutes
Hello Everyone... We have the following setup.. 1 x XSM7224S-100AJS (M7300) running 9.0.1.42 acting as a Core 2 x M4300-52G ProSAFE 48-port 1G and 2-port 10GBASE-T and 2-port 10G SFP+ acting...
- Nov 28, 2017
Hi Hopchen,
Apologies for the late reply...
Bascially this is the update...
Did everything recommended except the below item 3 as this option was not in my Core..
3. Allow querier mode each VLAN.
Switching > Multicast > IGMP Snooping > IGMP VLAN Configuration > Enable Proxy Querier mode for you VLANs here and click Apply.The site just confirmed that multicast is working fine now... :)
One thing I should mention that when I changed the multicast protocol, my remote connection dropped out for about 30 seconds... But then it came good.
Thanks you very much for your help on this...
Mayank
Hopchen
Nov 07, 2017Prodigy
Hey,
From what I understand, there is one routing hop in the network - your core switch. In that case, I would suggest to use PIM-DM instead. Also, the DVMRP config isn't quite right and that might be the issue. You only need mcast routing on the devices that is actually does the routing.
Second thing is the IGMP snooping querier being enabled on multiple switches. That is fine, but you need to make sure they are enabled for querier election mode then.
I have attached some documents to this thread. Download via this link:
http://files.netgear-support.com/go/?a=d&i=xTXv5kPxjA
Please have a read. These are home-made but they will explain it a bit more. The link will expire in 10 days.
So, my advise:
1. Turn off DVMRP on all switches.
2. Use PIM-DM on just the routing core.
3. Review IGMP snooping setup according to my document. You might not need to change anything here.
Any questions, let me know!
Cheers
mayank7489
Nov 13, 2017Aspirant
Hi Hopchen,
I seem to be having issue accessing your files.
Could you please attach again if possible.
- HopchenNov 14, 2017Prodigy
Hi,
I just tested and the link should still be fine. Just copy/paste this URL into your browser:
Does it still not work?
Cheers
- mayank7489Nov 14, 2017Aspirant
Good Morning Hopchen,
I just tried with IE, Firefox & Chrome from my PC and it did not work.
Just to Rule out internet/Proxy connection, I tried via my laptop on a 4G connection as well and same result. : (
Do you have Google Drive or one Drive... ?
- DaneANov 15, 2017NETGEAR Employee Retired
Hi mayank7489,
I can confirm that the download link posted by Hopchen is working and I was able to download the files.
Kindly click on the attachment (the paper clip icon at the right side of this post) to download the file. It is the same files that Hopchen posted for you and I just saved it as .pdf format so that I could attach it here..
DaneA
NETGEAR Community Team
