krobinson
Dec 02, 2013Tutor
Multicast video between netgear switches
I have a one VLAN (5) connected with a single port (port 1) LAG between a M5300 and a GS752. I have no issues pinging computers when they are connected to different switches. On the M5300 I have m...
Marto731
Dec 08, 2013Aspirant
Mr Robinson,
I have a few questions.
If you have 2 PC's, one on each switch, and on a "untagged " port in vlan 5, can they ping each other?
You say LAG. That is different from Trunking.
Is port 1 handling Vlan 5 traffic only, or other Vlans?
If the former, port 1 is "U", with PVID=5.
If the latter, it needs to be "T" for tagged in Vlan 5.
I can't answer re Multicast at the moment.
Can you advise firmwares of both M5300 and GS switch types.?
Thanks Marto.
Thanks Marto.
