wgstarks
Jan 02, 2018Aspirant
Need help creating vlan (802.1Q)
I have a GS724Tv2 switch which currently has all appliances connected on vlan1. The firewall appliance is connected to port1 and I have a wireless access point (AirPort Extreme) on port10. Its my unde...
TheEther
Jan 02, 2018Guru
VLAN 1 traffic should not have been affected by the changes you did for VLAN 1003. How did you determine that VLAN 1 traffic to the firewall was being blocked? Did you try pinging the firewall from a device wired into your switch?
Is your firewall set up to receive and send traffic tagged with VLAN 1003? Moreover, is there a DHCP server for that VLAN?
- wgstarksJan 02, 2018AspirantThe devices connected to the switch all lose access to the DHCP server running on the firewall. I can’t really say for sure at what point on the network the traffic is being blocked.
The firewall is configured for vlan1003.
