AevnsGrandpa
May 27, 2016Aspirant
Need to limit bandwidth (rate) by port
While I chose this model, I am not bound by it. I am needing a switch where I can limit rate or bandwidth by port. Here is the situation. My church streams and we currently have a 10Mbps down and...
- Jun 16, 2016
Hi AevnsGrandpa,
Let us know how it turns out. If it is working fine and this had answered your question, please mark the post as "Accept as Solution".
Thanks,
AevnsGrandpa
Jun 15, 2016Aspirant
Well it is in (105ev2) and i have it so all connections through it i have rate limited. We'll see!
- JohnRoJun 16, 2016NETGEAR Employee Retired
Hi AevnsGrandpa,
Thanks,
- AevnsGrandpaJun 19, 2016Aspirant
I actually went with the GS105Ev2. I didn't need all 8 ports. Setr the rate to 1Mbps and then did speed checks on Wifi and wired and indeed it is limited!!
One more question, I have port 1 connected to the DSL modem and ports 2-4 to the other hubs and devices. Is ingress and egress in reference to port 1? So data from the DSL modem (the internet) in the ingress to port 1 and what it is to the other ports?
Thanks,
Jeff
- JohnRoJun 20, 2016NETGEAR Employee Retired
Hello AevnsGrandpa,
The ingress and egress are on port 1 and the bandwidth is distributed equally on all active ports. So if you have rate limiting defined on port 1 then that bandwidth will be the divided to ports 2-4.
Let me know if I understood your questions correctly.
Thanks,
